Truck won't start after edge install.
So I installed a edge evolution last night it came off a buddys truck. he reset his PCM back to stock then he said here you can have this use it how you like. so We set it up went through the disclaimer and setup process. then proceeded to upload the tow program.
well everything went good it said programming complete then when we went to crank the truck for the first time it would not crank the injectors would not cycle nothing the truck is dead in the water. then We tried to return back to stock and well it is stuck at saying "initializing" what isa guy to do? it is currently sitting at ford waiting to get re flashed. |
Ever figure out what happened?
Did it come unplugged at all while you were programming it? This will blank your PCM. Once you get it all set, don't mes with the Edge, get some custom tuning. I still have my EVO, but i'll only ever use it for reading codes. |
