1997 F350 7.3L No crank, just click - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-16-2014, 09:15 AM Thread Starter
Angry 1997 F350 7.3L No crank, just click
My FIL has a 1997 F350 7.3L diesel that he has not drove much in the past year. Upon trying to start it lately, all he has got was a click. We have tried charging the batteries, and jumping it. We replaced the fender mounted solenoid, same result; we then replaced the starter solenoid, same results. We have tried shifting it into neutral, same results.
Batteries are about 18 months old, could it be the batteries are bad? They seem to fully charged, meaning that they are not taking any charge when placed on a charger.
Can anyone help?
Thanks!
Paul Krzywon
pkrazy11 is offline
post #2 of 12 Old 01-22-2014, 03:44 PM
Subscribed, much the same issue with a 04 6.0, click the key 10 or 15 times and it'll crank
fast_st is offline
post #3 of 12 Old 01-22-2014, 03:52 PM
Shadowfax's Avatar
Quoted: 9 Post(s)
sounds like terminals or a bad ground connection.
2015 f350 lariat
2003 Jetta TDI 5spd
Shadowfax is offline
post #4 of 12 Old 02-07-2014, 02:26 AM
Did you have the starter tested? sounds like you need some help finding where the click is coming from first. It almost sounds like you might have a bad starter or ground cable along the way. check for 13v at the starter terminal and at all three terminals with the key held in the crank position. Should be able to reach it over the top of the frame rail. Check for less than 1 volt between starter case and negative terminal while cranking.
fast_st is offline
post #5 of 12 Old 02-07-2014, 02:33 PM
midnite rider's Avatar
Quoted: 285 Post(s)
starter might be stuck try tapping it with a hammer while someone holds key in the start position, crude but effective.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #6 of 12 Old 02-08-2014, 01:37 PM
I have a 07 6.0. It shut off while driving down the highway. No crank #22 fuse blown, replaced fuse blew again. Upluged maf,oil pressure, coolent glowplug,fan, exuast back pressure, sensors,tried to start blew fuse. Uplugged pcm did not blow fuse. Plugged them back in one at a time ok till i plugged in last one closest to cab then fuse blew. Any thoughts anyone? This truck is driving me nuts.
harry is offline
post #7 of 12 Old 02-08-2014, 03:12 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
check all connections , i use to have to tap mine with a hammer while someone tried starting and it worked
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #8 of 12 Old 02-09-2014, 02:38 AM
Are you talking about tapping the pcm. Is there any way to test it?
harry is offline
post #9 of 12 Old 02-09-2014, 06:23 AM
Quoted: 285 Post(s)
I think he mean`t the starter.
-Tom
post #10 of 12 Old 02-09-2014, 06:38 AM
Are there any techs on line that could advise me on how to diagnose this problem. This is my work truck and needs to run. Thanks.
harry is offline
