Instantly no low pressure oil - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-30-2008, 01:13 PM Thread Starter
jpms's Avatar
Ok I hope by via the internet someone out there can help me.
I have talked to many mechanics my area and they all must be part installers because I get a different list of parts to replace in an order when each one doesnt fix the problem.
The truck ran fine, turned off, started and died, no start after that and the oil gauge never moves. It had a code P1212 so I started by installing a pressure gauge in the pressure switch on top of the resevor. No pressure, installed a pressure gauge at the plug above the oil filter, no pressure, turned the engine over and oil will slowly run out the plug hole at the filter but it doesnt fill the HP resevor.
So I am here, no start and no low pressure oil. What is causing this issue to happen instantly?
99' F450 4x4, 7.3 Intercooled, Manual trans, built date of 10/99 136,412miles.
Help me if you can, that truck is my way of life, no food on the table when it doenst run.
jpms is offline
post #2 of 7 Old 09-30-2008, 02:03 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Sounds to me like the HPOP is bad. Someone will be a long shortly but heres a for ya. Hope you get it fixed.
dhanna6powerstroke is offline
post #3 of 7 Old 09-30-2008, 02:31 PM
sikktruk01's Avatar
I'm no powerstroke mechanic but I'll take a stab anyway, sounds like you have a problem with your low pressure oil pump, I belive it supplies oil to the high pressure oil pump reservoir.
how's the oil level and quality ? reason I ask, alot of drivability problems arise from low oil levels and/or foaming.
here's a bump for ya anyway
platinum edition F250 crewcab, 7.3 powerstroke,8 inch fabtech, 37x13.5x20 kumho m/t, 20x10 A/R teflon thug,6 FOX shocks and stabilizer, stainless toolbox, line-x, 4 inch exhaust, AEM intake, wicked wheel, Dp-tuner, Autometer C2 Gauges, kenwood in dash TV/DVD with navigation, sirius, bluetooth and back up camera, infinity and JL audio speakers, PPI amp, 08 diff cover, braided brake lines, onboard air w/ train horns,E-Z down tailgate
sikktruk01 is offline
post #4 of 7 Old 09-30-2008, 06:30 PM Thread Starter
jpms's Avatar
Well I think I have a cracked pickup tube from the way it acts. All the messing around with it I dont know if I fixed it or not. I installed a new IPR valve, changed the filter and oil, checked the bypass and pickup screen, they appear to be ok. Primed the HP resevior, got it started with oil pressure. drove it 2 miles, engine sounds different and has alittle more power, but loads up very badly on fuel if you just rev it up sitting still. It will start but is slow to pick up oil on the low side yet, I did overfill it by a quart and half, due to priming the HP resevior. My fault not thinking ahead.
The engine acts very strange to me, maybe its right now and I am use to it being wrong, does the oil pressure gauge normally read pressure after it starts or before it starts up?????
Also, can you do an inframe oil pan removal or do you have to pull the engine completely out?? So I can get to the pickup tube.
For the near time I guess if it starts in the morning I will go to work, thanks for your help and let me know about the above questions I still am pondering.
jpms is offline
post #5 of 7 Old 09-30-2008, 06:33 PM
troid123's Avatar
Send a message via AIM to troid123
2006 F250 CC Short Bed King Ranch 4x4 (109,000 miles)
4" Turbo Back w/ 6" Tip
SCT x3 w/ Custom Tunes From DJ's/Innovative
03 turbo
Eclipse Navigation/DVD/CD/MP3 w/ Rear Camera
Rear DVD/MP3/CD Entertainment System
Escort Passport SR7 Built In Radar Detection System
K & N Cold Air Intake w/ S&B Replacement Filter
Roll-N-Lock Retractable Bed Cover
Nitto Trail Grappler LT295/70R18
***SOLD 10/31/11***
New Truck:
2011 Ford F-150 Limited 6.2L Super Crew
troid123 is offline
post #6 of 7 Old 09-30-2008, 06:46 PM
tonypagnano's Avatar
Send a message via AIM to tonypagnano
the gauge should read oil pressure no more than 3-5 seconds after the motor starts, and unfortunately i think us 7.3 guys have to pull the motor to drop the pan....
2010 F350 XLT extended cab short bed
89 D200 cummins 2wd 5 speed
tonypagnano is offline
post #7 of 7 Old 10-01-2008, 03:45 AM Thread Starter
jpms's Avatar
Well it started this morning, it is about 3-5secs after the truck fired up that oil pressure shown on the gauge. I guess I will try it and see if it makes it through the day.
jpms is offline
