01 7.3 HELP TRUCK SHUTDOWN AND WONT START!!!!! - Ford Powerstroke Diesel Forum
Old 09-29-2008, 06:45 PM
I was driving my truck today and it started to run terribly rough knocked a few times, sounded like it was running on one cylinder and then shut down. IT WONT START AT ALL NOW! I was having problems with it off and on where the engine would shake like crazy for a while and then run like normal. It did this for a while and finally had it today. I dont think its the CPS because it didnt just shutoff randomly, it got worse and worse really quick and now it wont start. What is the problem?
Old 09-29-2008, 06:54 PM
Mine was doing some thing simular. I did the 10K and smoothed out than I repaced the ICP took out 10k and runs fine.
Old 09-29-2008, 07:02 PM
check your oil level and or change it.
any codes ?
Old 09-29-2008, 07:04 PM
I will check my oil level, no codes although it did read turbo pressure low yesterday, I figured that was unrelated to the issue just caused by it. I cleared it and I havent seen it again.
Old 09-29-2008, 07:06 PM
also check for blown or loose intercooler boots/hoses
Old 09-29-2008, 07:09 PM
duct tape & zip ties
Scan for codes, check the oil level, check the cps ( even replace it), Check the fuel supply pump, fuel filter, fill the fuel tank up. The fuel gauge may not be accurate and you may have an empty tank.
What you are describing sounds like fuel starvation. Which most likely is a fuel supply problem. Even the pick up tube in the tank could be clogged.
Have a fuel pressure test done. See how much fuel pressure you have coming out of the fuel supply pump.
If you do not know where the fuel supply pump is located. It is located on the driverside frame rail, it is almost directly underneath the driverside door on the inside of the frame rail. Check and see if you have power coming to the pump.
Another thing you can do is crawl underneath the truck. Have someone turn the key on the pump should run for 5-10 seconds to prime the system. If you do not hear the pump kick on when the key is turned on then you could have a bad pump or no power going to the pump.
If you have no power going to the pump check the fuses in the cab and under the hood. If you have no blown fuses then you need to start checking the wire going to the pump for continuity. This should tell you if the wire going to your pump is shorted out.
Old 09-29-2008, 07:17 PM
all that should keep you busy for a while
bigcountrysg bout covered it all. (good advice)
Old 10-07-2008, 03:18 AM
So what have you found out.
Old 10-08-2008, 08:21 AM
The dealership said it was my fuel pump, so I replaced it and it got better for a little while but now has started again. I have a veggie system and I think it has something to do with it. When I run it on diesel it runs fine. When I switch it to veggie, 5 minutes later it starts running really rough and shakes really bad. If I switch it back to diesel, 5 minutes later its running fine again. I have no idea what the problem could be. Its like its not getting fuel but I just replaced the veggie filter and other than that there isnt anything I can think of that would impede the flow on the veggie side. Any ideas?
