6.4 -30 bellow PLEASE HELP - Ford Powerstroke Diesel Forum
post #1 of 1 Old 01-07-2014, 10:55 PM Thread Starter
Exclamation 6.4 -30 bellow PLEASE HELP
truck threw these codes
P006B
P2563
P0087
U3F25
its -30 truck wouldn't start. got it in a warm garage to let it thaw and began to drain the water separator on the frame rail after a hour and a half of sitting. I drained 1/2 gallon of crap out of it and let it run. the check engine light then went out. I drove it for about an hour and the check engine light came on with this code
P2536
I popped the hood to find coolant all over my reservoir. My boost seemed a little higher than normal also. one of those codes are for the EBP sensor witch I replaced 2 days ago! WHAT DO I DO PLEASE HELP!!!
turbotony is offline
Tags
6.4 , 6.4 fuel issues , 6.4 motor problems , cold weather
