help 06 6.0 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-06-2014, 05:37 PM Thread Starter
help 06 6.0
I need help my temp gage is all over the place no heat out off the vence I have put a water pump a hearter core, cluch fan, termastat and still no heat can enyone help
holts11 is offline
post #2 of 6 Old 01-06-2014, 06:00 PM
Colin7.3's Avatar
Sounds like you an air pocket somewhere
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #3 of 6 Old 01-06-2014, 06:34 PM Thread Starter
the temp when up to 230 and then I felt the top hose and it was not that hot and it felt like it was grgaling in the hose when I took the cap of the degas bottle the temp when down and it got hot out the vents
holts11 is offline
post #4 of 6 Old 01-06-2014, 06:38 PM
drivininidaho's Avatar
Quoted: 81 Post(s)
yep sounds like you have/had an air pocket in the system. if its getting that hot...
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #5 of 6 Old 01-06-2014, 06:45 PM Thread Starter
what is the best way to get it out
holts11 is offline
post #6 of 6 Old 01-08-2014, 07:41 AM
Quoted: 81 Post(s)
Iirc turn heat all the way up set on defrost and open degas cap. Could be wrong. Free bump for more info
sent from everywhere...
Lyndel
'04 F25 SD CCSB
