99 F250 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-05-2014, 09:33 PM Thread Starter
99 F250
Hi, I have a 99 F250, 7.3 diesel. Its -10 and -30 windchill, The truck was plugged in all night and started fine, I drove about 5 miles and it started chugging and stalled. I gather the fuel gelled. I put diesel boost in tank first, then diesel 911 in tank and started again, it ran rough as hell and chugged to a stall again. So I added 911 to the fuel filter but now it wont even turn over. I have power to all gauges etc... but wont crank. I jumped it with another diesel truck to no avail. Is it possible for the block or starter to freeze??? Where to go from here. The truck is now in an empty parking lot and cant be plugged in or anything. Very frustrated.
Wade123 is offline
post #2 of 2 Old 01-05-2014, 10:03 PM
allergic to hot weather
95and05's Avatar
Send a message via AIM to 95and05 Send a message via MSN to 95and05
No crank?
Check all fuses under hood and in cab. Try neutral instead of park in case neutral safety switch is not hitting properly in park.
Keith in Alaska (lovin it)
94 IDI
95 7.3 ex cab L/B 4X4 (D66 stage 1s 4" Turbo back 6637 air filter and bully dog chip)
05 6.0 Excursion 4X4 (stock)
10 6.4 F350SRW CCLB manual trans (stock)
95and05 is offline
