Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 11-18-2006, 05:40 PM
cajuncoastie cajuncoastie is offline
2003 F250(7.3) misses.... then dies
Hi all. I am Mike... a military man from Louisiana, thus the name. Anyway, I have a 2003 F-250 with the 7.3 l in it. While driving along, the truck seems to loose fuel for a brief second, then the "check engine" light comes on. At times during idle, she will die out also.. I have no idea. If anyone responds, please use the laymen terms instead of the abbrieviations... not too familiar with the lingo.. Thanks.. Mike
Old 11-18-2006, 06:00 PM
Logan Logan is offline
The Fat Mod
First off welcome, Have you pulled the codes? Kind of sounds like a classic CPS going out. CPS is Cam positioning sensor.
Old 12-07-2006, 06:34 PM
Diesel_Diagnostician Diesel_Diagnostician is offline
Powerstroke Diesel Enthusiast
This problem seems to be common but usually no check engine light, (at least when I have to diagnose it) anyways as brrs3633 said it does sound and it is most likely the Cam sensor...
