911 Oil Leak! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-03-2014, 04:03 PM Thread Starter
911 Oil Leak!
Ok driving home from work my boost gauge was whistling like the fitting was loose. Pulled it out and it was loose but there's oil on the line! Boost is tapped into intake elbow like every company shows you to do. What is this? 2005 F250 4x4, 4" turbo back cat and muff delete, sinister diesel coolant filter kit, Zoodad mod, boost, egt, feul psi gauges. Other than that it's stock. Someone let me know it's not a major issue. Kinda freaking out!
DirtyDiesel05 is offline
post #2 of 5 Old 01-03-2014, 04:49 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
i dont have a 6.0, but doesnt the ccv route into the intake?
if so could it possibly be from the ccv?
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #3 of 5 Old 01-03-2014, 10:52 PM
hdodt's Avatar
Yup. Your ccv dumps oil vapors into the intake which coats everything from the turbo to the intake valves....
2006 F350 Lariat
EL CAT1 coolant and coolant filter.
95k miles. Oil cooler changed at 93k.
Oversized turbo oil drain tube.
hdodt is offline
post #4 of 5 Old 01-04-2014, 06:39 AM Thread Starter
So is this normal or should I do something about this?
post #5 of 5 Old 01-04-2014, 08:04 AM
hdodt's Avatar
It's normal. Doing something about it is up to you. There's a ccv mod that some do to keep the oil out of the intake. Just search ccv mod or ccv reroute.
2006 F350 Lariat
hdodt is offline
