2005 6.0 f350 wont start hot - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-03-2014, 01:56 PM Thread Starter
Send a message via Yahoo to beck549
ok here is my problem truck starts when cold idles for 15 min it will die and not start back.
i took the icp valve off and blew air in to it while activating the ipr valve i have no air leaks coming from the valve covers have a small air leak coming from the turbo oil drain.
and when it is running the low oil pressure light comes on on the dash
where should i go from here i am stuck any help i would appreciate it thanks
beck549 is offline
post #2 of 2 Old 01-04-2014, 05:22 PM
Check base engine oil pressure. Oil pressure switch is a 6 lb switch.
cattec3612 is offline
