truck has lost power,stalled,etc.
Started the truck this morning and it ran great for about 5 miles.It started bucking,surging while driving and eventually lost all power and died...I stopped it on the side of the road.
15 minutes later it started back up and I attempted to drive it up to an empty parking lot.It was bucking and surging again and had no power and was also smoking very bad. I let it sit running in the parking lot and it idled very well.I went to try and get it back home and it was doing the same things. It died on me twice during the 5 miles back to my house. I had a spare CPS so i went ahead and replaced it but no change in condition.I havent driven the truck in a week and I really need it today of all days. Any ideas on what I can check??? I have checked all electrical connections and they make no difference...also I have no Codes or CEL either. |
Did your turbo take a crap?
Is it a fuel restriction?
sounds like a weak fuel pump. ar you able to check fuel pressure at the shrader valve?
It is still making boost and the turbo seems fine.
I just unplugged several sensors and checked the connections at the valve covers and had no change. I did unplug the ICP sensor and found it filled with oil.....is this my problem????????? |
Started truck just a few minutes ago and it still has a miss throughout the rpm range.
No Check Engine Light and No Codes whatsoever........ Dont know what to look for now |
If the IDM got wet would this cause my problem???????????????????
Ok.Let truck sit for 24 hours.Checked HPOP levels and all was ok.
Started truck and upon startup it began smoking white/blue smoke continuosly and then started smoking what seemed like everytime the engine made a revolution(chugging smoke out) Truck ran for three minutes and then died on its own. Still no CEL and no codes whatsoever. Oil is clean Fuel is clean Im lost |
