White smoke and shakes? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-31-2013, 02:26 PM Thread Starter
Quoted: 3 Post(s)
I have a 2000 Psd mods in sig. I just installed a billet wheel and FRx from riff raff. I started the truck and was getting ready to back out of the garage when it suddenly started shaking real bad and a decent amount of white smoke was coming out of the exhaust. It ran for 30-60 sec tops and then I turned it off. I called clay at riff raff and he did not respond. After I left a message I decided to fire it up again and the same thing happened. I have absolutely no idea what to do or where to start. If you guys could help me out I would greatly appreciate it.
2000 PSD, 4in Exhaust, 6637 Intake, Zoodad, TS Canned Tunes, JWVB, Billet Wheel, FRx
ilovemy7.3 is offline
post #2 of 5 Old 12-31-2013, 02:30 PM
Rodslinger's B1TCH
air in the fuel system. take it for a drive.
steve604 is offline
post #3 of 5 Old 12-31-2013, 02:32 PM Thread Starter
Quoted: 3 Post(s)
I'm not doubting you but would that cause the smoke too?
post #4 of 5 Old 12-31-2013, 02:35 PM
Rodslinger's B1TCH
20. You should take the truck out to run it for at least 10-15 minutes as a way to ensure that all
potential air has been completely purged from the entire fuel supply/return system. In rare
cases, it may take a little longer to purge all air from the entire system,
I think I might install one of these on mine now. I didn't realize they were so cheap
steve604 is offline
post #5 of 5 Old 12-31-2013, 02:38 PM
Rodslinger's B1TCH
yes. I've had my truck smoke for a while after changing the fuel filter due to air in the system. I think it's due to a screwy spray pattern coming out of the injector so some of the fuel just drops onto the piston and slowly burns away in the form of white/blue smoke.
steve604 is offline
