Coolant Leak 1995 7.3 turbo
I'm having a coolant leak I can't tell where its coming from, but its draining down the valley of the motor and off the back. Now I'm fairly new to the powerstrokes but from what I have read and heard they are very predictable, what I mean is there a few select parts that are known to cause problems. I was wondering if this was the case with any sort of coolant leak problem. Im also having a slight oil leak out of the bung on the oil pan were the dip stick tube goes in. Any help on either topic would be appreciated.
-Chris |
1995 most common coolant leak, water pump ,or thermostat housing , thats it
The only coolant that would be up in the valley would be from the heads. Thats all I can think of.
O and are you sure it's coolant or is it fuel?
For the leak around the dipstick you are tallking about I have the same problem and I was told by a mechanic who checked it out that the pan is beginning to rot around the dipstick but I havent got it fixed becuase he said it will cost more than its worth right now.
im pretty sure its coolant but ill have to do some more investigating. its a good thought though what ever it is its green tint
When it comes to the oil pan leak there is an o ring behind the large nut on the side of the pan International offers a kit to fix the problem you have to be careful not to drope the in side piece into the pan the part # is1846146091
