looking for tips - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-30-2013, 02:59 PM Thread Starter
looking for tips
looking for tips on getting the exhaust off the turbo on my 6.4 so I can change the hpop. that is the only thing in my way now .have five bolts left to remove.
jtm2000 is offline
post #2 of 5 Old 01-04-2014, 05:58 PM
First thing I've removed when doing this cab on is to remove the pipe between the horizontal EGR cooler and the turbo pipes. The the EGR pipe bracket. To get to the bolts it's a combination of wrenches, 1/4 and 3/8 drive ratchets and 10mm sockets (short and wobbly). Those bolts will round easily if you have a worn out socket or wrench.
cattec3612 is offline
post #3 of 5 Old 01-04-2014, 06:22 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Little confusing since a 6.4 doesn't have an HPOP. What exactly are you working on?
dhanna6powerstroke is offline
post #4 of 5 Old 01-08-2014, 05:31 PM Thread Starter
what is the pump that is in the motor valley under the turbos?
jtm2000 is offline
post #5 of 5 Old 01-08-2014, 06:37 PM
Mod Newbie
Quoted: 20 Post(s)
It has a high pressure fuel pump (HPFP) if it's a 6.4
