2001 7.3 excursion trouble - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-29-2013, 12:22 PM Thread Starter
OK have had no problems till I purchased fuel last night, less than 5 miles later started chugging tons of smoke , only way it would run is foot on floor. will start and idle but missing and a lot of smoke. When we purchased it we were told it had a programmed computer in it so it didn't smoke at all. it actually ran really well with no smoke at all. I scanned it and ran a buzz test on injectors and all passed. ran a cylinder balance test and it gave codes p0272 and po269 #3 AND #4 balance fault .checked harness at v-cover seems ok and it did pass the injector buzz test . HELP please asap need it for work in the am. thanks joe
kmhtech1 is offline
post #2 of 11 Old 12-29-2013, 12:39 PM Thread Starter
any help ?
kmhtech1 is offline
post #3 of 11 Old 12-29-2013, 12:48 PM
wvrrcarknocker's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Send a message via Yahoo to wvrrcarknocker
If you're thinking its related to a bad load of fuel, i'd either A. Drain the fuel, change your fuel filters, and get a fresh tank and add some diesel kleen 911 in the red bottle, or B. Just change the filters and add the red bottle, see what happens. I don't know a lot about the 7.3, so i'm sure some more knowledgeable guys will be by shortly.
wvrrcarknocker is offline
post #4 of 11 Old 12-29-2013, 12:52 PM
jesilvas's Avatar
Quoted: 3 Post(s)
If it happened with the fuel, I'd suspect that.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 11 Old 12-29-2013, 01:18 PM Thread Starter
I believe I got the fuel issue taken care of but it now has a horrible miss and the codes and smoking very bad could have the fuel ruined the injectors
kmhtech1 is offline
post #6 of 11 Old 12-29-2013, 01:21 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I think you probably just need to run it out good and hot for a while.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 11 Old 12-29-2013, 01:28 PM Thread Starter
after taking care of fuel and filter put a long screwdriver on pedal and let it run at 2000 for about 20 min. still smoking and missing . had my whole end of town in a cloud .
kmhtech1 is offline
post #8 of 11 Old 12-29-2013, 01:50 PM
jesilvas's Avatar
Quoted: 3 Post(s)
What color smoke? I mean drive it down the road and put it under load.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 11 Old 12-29-2013, 02:33 PM Thread Starter
blue tint don't smell like coolant and very heavy raw unburnt fuel. it has ran long enough to clean the system . continues to tell me # 3-4 on balance test. need to know if there are tests to do before replacing the injectors. have done the buzz tests and all injectors passed. but # 3 and 4 fail the balance test.
kmhtech1 is offline
post #10 of 11 Old 12-29-2013, 02:34 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I guess when you say balance you mean contribution test as the same thing?
4R100, 2wd
330,000 + miles
jesilvas is offline
