TURBO PIPE BLOWING OFF
I have a 06 F250 6.0 W/ 206K. all orig except Exhaust... Replaced Egr and turbo hose @ 95k, 135 U-joints and Rearend fluid, Turbo Stand pipes...+ 4" exhaust ( Best move for $$$) Tranny fluid @ 35, 70, 97k, 8 inj and High pressure oil pump and EGR Cooler along w/ oil log o rings @ 175k... for reliability purposes after loosing 1 inj. Great truck, no oil useage..... Change oil evy 5k...This weeked it started blowing off turbo hose (TOP) I put on new one w New Clamps, but can't keep it on.... No real reason, flat land///Hill///just blows off, may last 2 min may last 5-6 hours....What could be the reason for this, as for I'm tired of living in the engine compartment (LOL) The seat is uch more comfortable!!! Thanks MDE--FBT. ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++ K I finally got home and pulled radiator, pulled Cooler, I took end off of cooler and washed out unit completely.....really not alot of film inside. I resealed and installed cooler radiator....Went 1/2 mile up the road and the damn thing blew off again......... Where can I look now????? Now at least i know it's not a oil build up in the cooler.
Last edited by FreedomBikeandTrike; 09-10-2008 at 12:51 PM. Reason: 911 DIDN"T WORK ..... WHAT NOW!!! |
I have heard the EGR can clog intercooler with oil. But that is just what i have heard.
woops I mean CCV not EGR
CCV?
What is that?
crank case vent. It vents crank case presure into intake so it can be burned usualy it is more than air it is a fine spray of oil with the milege you have on it it is possible to clog intercooler.
Inter cooler, Do U mean Air Cooler ( Radiator)
The radiator looking thing youre tubo pipe goes to in front of radiator. I am no tech this is what i read on hear.
Than You, This is my own Diagnosis, but need to hear it from someone else.!!... Does anyone know if this unit has a drain plug, or do I need to Pull it out?? xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx NO DRAIN PLUG...... BUT NOT PROBLEM....WHAT TO LOOK FOR NOW
