No oil pressure after replacing oil cooler O-rings 2003 7.3L - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-11-2013, 01:27 PM Thread Starter
Exclamation No oil pressure after replacing oil cooler O-rings 2003 7.3L
I just replaced o-rings on oil cooler with a lot of help from this forum. I filled the truck with 15 qts oil and started it up. It started rough at first, I saw the oil pressure guage go up, then engine smoothed out but just a minute or two later I noticed the oil pressure guage go back to zero and the truck stalled. I looked all around and did not see any signs of oil leakage. I started the truck again but no oil pressure so I shut it down. I pulled the dipstick and there was not even any oil on it! I am afraid to run the truck now since I dont have pressure or even any oil on the dipstick. I am assuming the oil is in the coolant since its not on the ground. Is it possible for these O-rings to come out of position as you reassemble the cooler? Spent a lot of time on this and need truck to get back to work so any advice would be appreciated. I know I am going to have to take it back apart but sure dont want the same result twice. Outside of the oil leak, the truck ran fine before I pulled the cooler. Any help would be extremely appreciated. Thanks!
2003 F-350 7.3L 4x4
TX2003PSD73 is offline
post #2 of 10 Old 12-12-2013, 06:53 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1744 Post(s)
Feedback Score: 4 reviews
how does your coolant look? any oil get in there? I'm assuming there's not a huge puddle of oil under the truck right?
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #3 of 10 Old 12-12-2013, 07:26 AM
Quoted: 786 Post(s)
Fyi, your dipstick doesn't go to the bottom of the pan. So roughly 4 QTS low will show nothing on the dipstick. Did u refill the coolant before u restarted the engine? If u did, your coolant reservoir would overfill. If not then your oil is in your coolant system.
And yes, it is possible you "rolled" an O-ring when pressing the tube back into the housings.
Corey@CNCFAB is offline
post #4 of 10 Old 12-12-2013, 11:04 AM Thread Starter
finally got back to work on the beast and yes the oil is in the coolant. I removed the block coolant plug and out it came. Now to figure out why.
post #5 of 10 Old 12-12-2013, 02:44 PM Thread Starter
pulled out the cooler and the front black o-ring had rolled up over the lip of the cooler. Was pinched so I got another one. No the darn thing wont start. Just cranks and cranks. Frustated and quitting for the day.
post #6 of 10 Old 12-12-2013, 02:46 PM
with it running out of oil, it'll take awhile to build pressure up enough to fire the injectors again......get a charger on it to keep your batts up and keep cranking. It'll fire.
post #7 of 10 Old 12-12-2013, 03:30 PM Thread Starter
Thanks Nick. I'll sleep better tonight knowing that. Will tackle it again in the am.
post #8 of 10 Old 12-14-2013, 07:25 AM Thread Starter
Checked oil level in HPOP. Was low so I filled it. After a little more cranking it fired right up. And best of all no leaks! So I'll flush the cooling system real good and put it back together. I truly want to thank everyone who gave advice on this thread. It was my first 'major' repair attempt and could not have done it without the help I got on this forum.
post #9 of 10 Old 12-14-2013, 07:43 AM
Quoted: 786 Post(s)
Sure thing. Wish they were all as easy to fix as yours. Lol
post #10 of 10 Old 12-14-2013, 09:42 AM
Ha! I second that! Glad to hear she's up and running!
Tags
oil cooler
