skipping - Ford Powerstroke Diesel Forum
Old 09-01-2008, 04:52 PM
skipping
any ideas on this?- 04 6.0 sct auto , towing a trailer full of equiptment back from the fair, sct set for 65hp towing w/jake brake . i stop at a light and the truck starts skipping bad! very low power when i take off no cel no smoke of any kind the skip comes and goes gets worse and gets better , i stop to get some food check everything over , let the truck set for about an hour when i start it it runs fine , then starts skipping bad all of a sudden comes out of it runs great for an hour then i stop at a light and it starts all over again. made it home all guages stay in the norm no cel no smoke???????? injector? wiring harness?
Old 09-03-2008, 01:09 PM
Codes????? Possibly an injector or wiring.
Old 09-03-2008, 02:15 PM
there were no codes for the first 2 days ,and the skip would come and go , today i took off the turbo and checked to make sure the vanes were not rusty or sooty there was no rust and very minimal soot however there was a head of a bolt inside the " remanufactured turbo " exhaust side just floating around very small stainless looks identical to those behind the turbine wheel but none were missing i could see no damage done any where , put it back togeather left the "floatie" out and when i started it up it immediately started to skip threw a code 263 injector 1 fault or valvetrain, and then ran fine till i got home now it is doing the same thing again . no check eng light no codes. i did wiggle the wires at injector 1 and it immediately smoothed out i let go now i cant get it to stop skipping . i think i will try to pull the valve cover and check inside when she cools off? well see what happens , i have to pull friday and i want 8 not 7 cyls
Old 09-04-2008, 06:35 AM
Sounds like the wiring for the injector is damaged. If its on the harness side try getting a new connector, if its in the injector side a new injector is neccesary.
Old 09-05-2008, 12:20 PM
fixed- injector 1 the bolt that holds the top togeather near wiring had come loose the nut was never crimped and was laying in the top of the head, i think i could have fixed it with new bolt and nut but didnt have time to risk doing it twice so i put in a new injector thanks for the input . still a little concerned about the bolt i took out of the turbo makes me wonder about the quality of remanufactured parts?
