wont start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-06-2013, 06:20 PM Thread Starter
wont start
hello looking for help my daily driver is down .was driving homw and it just quite. it cranks but will not start .tried to reflash it but no change .it spits out these codes u0115,u0100,u2511and 2511.any ideas.
jtm2000 is offline
post #2 of 5 Old 12-07-2013, 06:25 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Probably be faster to just go to Google, enter the engine displacement (you've left US guessing ) the word FORD (again I'll assume your truck is a Ford) and then DCT Uxxxx and follow the results which will take you to discussions from all forums related to them....
NoRalPh is offline
post #3 of 5 Old 12-07-2013, 06:58 AM
If its a 6.0 start by checking your ICP pressure, if I remember correctly it needs a minimum of 500 PSI from your High press. oil pump. If your not getting that, there is a problem somewhere in you HPO system... first check the IPR... if its not that your gonna have to start tearing S&*( apart.
If you dont have a gauge unplug the ICP and try to start it. If it starts you need and ICP.
2003 6.0 F250 "Onyx"
4inch lift
35'' Falken Wildpeak AT
SCT FX3 Performance tune
Edge Insight CTS
Edge EGT probe & Fuel Pressure sensor
Blue spring upgrade
Bulletproof Diesel EGR Cooler
Updated Motorcraft Oil Cooler
Sinister Diesel Coolant Filter
Rotella ELC
MBRP 4'' Turbo Back SS Straight pipe
Alpine head unit
Rockford Fosgate speakers
Still need to stud it....
aeby07 is offline
post #4 of 5 Old 12-07-2013, 03:08 PM Thread Starter
thanks and yes its a ford f250.
jtm2000 is offline
post #5 of 5 Old 12-07-2013, 03:11 PM Thread Starter
its a 6.4 l I even tried download the stock program. cranks but wont start .
jtm2000 is offline
