No start after dummy plug replacement - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-01-2013, 05:42 PM Thread Starter
Please help!
My truck (220k miles, no known mods other than straight exhaust) started having hot start problems a couple weeks ago. Thanks to this forum, I narrowed the possible culprits down and started with the fuel rail plugs an stand pipes. The passenger side dummy plug o-ring was severed and the driver side was at about 50%. After replacing the driver side, I reassembled and attempted to start the truck. I wanted to make sure everything was ok before tearing into the other side. No go. It turned over but did not 'fire'. I disassembled and checked all connections including FICM. They were loose, so reinstalled them and placed wedges under to ensure their proper connection. Still no go. Went ahead and tackled the passenger side. No major problems with that side. Truck still won't start, but now it fires (I know this is not a proper term, but you know what I mean!) every once in a while after about 2-3 attempts at 10+ seconds per crank. while cranking it blows white smoke out the tailpipe.
Any thoughts?!? Thank you!!
Aaron
aj2006 is offline
post #2 of 11 Old 12-01-2013, 05:55 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Keep cranking.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 11 Old 12-01-2013, 06:03 PM Thread Starter
As in the gremlin will blow out the tailpipe and everything should be fine after an initial start?
aj2006 is offline
post #4 of 11 Old 12-01-2013, 06:06 PM Thread Starter
BTW - oil change and fuel filters replaced about 500 miles ago, air filter has about 5000 on it.
aj2006 is offline
post #5 of 11 Old 12-01-2013, 07:16 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
If it's smoking out the pipe that's a good sign. Keep cranking. It will fire up.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
The Following User Says Thank You to Tuscany For This Useful Post:
aj2006 (12-01-2013)
post #6 of 11 Old 12-01-2013, 07:19 PM
Crank for 30 secs. Rest for a min keep someone doing that she ll fire. Me personally i just keep the key turned if th batterys will keep up. Those starters are tough
2006 FORD F-250
302,000 miles still running like she has 50,000
beat on everyday
EXTENDED CAB LONG BED
SINSTER EGR DELETE
HEAD STUDS
SCT WITH IDP TUNES
5 IN STRAIGHT PIPE EXHAUST
4 IN DOWN PIPE
6.4L BANJO BOLTS
BLUE SPRING UPGRADE
RCD 68mm S300 Turbo
RCD 205/200 sticks
own diesel shop in Sarasota
OFF ROAD DIESEL
1985 CATTLEMEN RD
SARASOTA FL 34232
JOSH 941-348-9221
powerstrokedieself250 is offline
The Following User Says Thank You to powerstrokedieself250 For This Useful Post:
aj2006 (12-01-2013)
post #7 of 11 Old 12-01-2013, 07:43 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Don't do that. 20-30 second intervals with a minute or more to cool down or you will burn up the starter.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #8 of 11 Old 12-02-2013, 08:49 AM Thread Starter
So it finally cranked up! But now it's running rough and has no power. Took to parts store to have codes pulled. They pulled 15 codes, ranging from all 8 injectors to glow plugs, cam position sensor, crank position sensor, turbo underboost... Any ideas?!
aj2006 is offline
post #9 of 11 Old 12-02-2013, 09:07 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Yeah your FICM harness isn't plugged all the way in.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
aj2006 (12-02-2013)
post #10 of 11 Old 12-02-2013, 10:00 AM Thread Starter
That was it exactly! crawled in with it running and played with the connections. Smoothed right out. Made tighter shims and now we're in good shape. thanks for all the help!! First venture into diesel repair after years of working on gas engines, will do it again thanks to great and timely feedback!
aj2006 is offline
