Stuck on the side of the highway! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-24-2013, 04:29 AM Thread Starter
jmoney330's Avatar
Stuck on the side of the right now guys...
Truck has had a bad surge between 55-75 mph for a week or so now. Surged a little bit at idle too.
Well all of a sudden the truck died and here I am right now 30 miles from home in my truck with the hood up and no one answering the phone....
I unplugged the icp sensor and tried to start it but it's still a crank with no start. I have an SCT livewire but it wasn't reading any codes.
My fuel light just came on as it died so I don't think that's the problem.
So... Uh help please?
Sold
2005 F250 SD SCLB. OEM Gaskets, ARP HeadStuds, EGR Delete. BulletProof Diesel 6-phase 58v FICM. Sinister Coolant Filter. STC Fitting, Blue Spring, Stand Pipes and Dummy Plugs. 35" Cooper Discovers on Ford Factory Rims. GlowShift Max Tow gauges. 3" Lift. SCT Livewire (Canned Tunes at the moment, soon to be Looney Tuned). Kensun 6000k Headlights & Foglights. Zoodad Mod. Problem child
jmoney330 is offline
post #2 of 12 Old 11-24-2013, 04:35 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Throw out were you are at just in case somebody is close.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 12 Old 11-24-2013, 04:38 AM Thread Starter
jmoney330's Avatar
Alright route 224/277 right off I-77 in Akron OH headed westbound.
Sold
post #4 of 12 Old 11-24-2013, 04:55 AM
Quoted: 780 Post(s)
Make any difference if you load ur stock program?
Corey@CNCFAB is offline
post #5 of 12 Old 11-24-2013, 04:57 AM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Bryan (goes by the screen name Tuscany) is down that way. Have you tried giving him a call?
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #6 of 12 Old 11-24-2013, 05:01 AM Thread Starter
jmoney330's Avatar
Never thought to try that so I just tried but my battery is too low to have it load.
Well right now I'm at least an hour probably more than that north of him. I might as a last resort.
Sold
post #7 of 12 Old 11-24-2013, 05:05 AM
Quoted: 780 Post(s)
Truck batteries. I dont know anything about the SCT's. Didn't think they had a battery??
post #8 of 12 Old 11-24-2013, 05:07 AM Thread Starter
jmoney330's Avatar
Yeah sorry I meant the batteries on the truck, lol.
Sold
post #9 of 12 Old 11-24-2013, 05:11 AM
Quoted: 780 Post(s)
Did you run them down pretty quick trying to start it? Or that may be your issue and your truck shut down due to low Ficm voltage.
post #10 of 12 Old 11-24-2013, 05:17 AM Thread Starter
jmoney330's Avatar
Well my radio stays on for 5 minutes after you turn the key. I only tried starting it 3 times or so.
And I will go ahead and rule out the ficm because I have the bulletproof diesel 6 phase.
Sold
