Sucking air from fuel tank - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-13-2008, 07:34 PM Thread Starter
JSchuricht's Avatar
Just installed a aux tank, but am having a issue with the stock tank sucking air. Looking for ideas on where the leak is coming from, as I can't find a leak in the solenoid and the aux tank works fine.
JSchuricht is offline
post #2 of 2 Old 08-14-2008, 06:10 PM Thread Starter
JSchuricht's Avatar
Never mind, found the problem. When I was redoing the fuel lines, I swapped the return from the Airdog with the return from the engine for less restriction. Didn't know about the mixing chamber in the tank... ditched the mixing chamber and the fuel system works properly now.
