Fuel Leak - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-18-2013, 03:27 PM Thread Starter
Fuel Leak
Have come to find out it is not antifreeze but fuel leaking out of the bellhousing flywheel cover on my 1998 E350 7.3 litre former ambulance..still having a hard time locating the source of the leak..wondering if anyone else has come across this problem..any help would be appreciated...
joecool1 is offline
post #2 of 3 Old 11-22-2013, 06:49 PM
85burban's Avatar
most likely coming from the water separator drain on the back of the filter housing and running down the valley and between motor and tranny. they are known to leak and you can get an oring kit and rebuild them fairly easy. that's where i would check first.
85burban is offline
post #3 of 3 Old 11-24-2013, 03:56 PM
also check the fuel line that runs on the side of the head on the inside of the block. cake with an e-series. the bolt hold down wears a hole in it
jeby64 is offline
