intermittent miss/stall/dies - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-11-2013, 06:43 PM Thread Starter
Buckeyepsd's Avatar
Quoted: 3 Post(s)
ok so my truck has been randomly stalling/missing/running like crap. It usually happens when i go over bumps (big ones) also when the truck is under load (going up steep hills) then letting off the pedal. On the highway it will drop like 200-300 rpms when i hit a bump almost like its losing fuel pressure.
Ive already replaced the ICP, cleaned the IPR, changed the CPS twice, and put in a reman IDM (I thought it could be electrical). None of these have helped. The truck isn't and hasn't thrown any codes no CEL or SES light either. So now I am leaning towards a fuel issue. My question is where do I start? Are there any relays or electrical connections that could be rattling loose when I hit the bumps? Ive checked the UVCH and that seems fine. I guess what I'm asking is where do I start? is it a pick up line issue? bad fuel pump? Bad injector?
This problem is getting annoying and I need it to be fixed, any help or suggestions are much appreciated. Thanks in advance guys.
02 F250 CCSB Lariat 4x4
38R, Rosewood Stg 1's, AFE Stg 2, 4" Turbo Back, Tuned, Tranny, 4" Lift
Buckeyepsd is offline
post #2 of 5 Old 11-11-2013, 07:13 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I personally have no experience with this but i know one member had absolute fits with his truck doing simalar things as yours and his ended up being the fuseable links right by the power distribution box in the engine bay. Otherwise search "Diagnosing a 7.3 no start" and i have a thread that states everything needed for a 7.3 to run it may help you figure out your problem as well
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 5 Old 11-13-2013, 01:53 AM
Quoted: 861 Post(s)
Feedback Score: 3 reviews
50 cent mod
Corey@CNCFAB is offline
post #4 of 5 Old 11-13-2013, 02:39 PM Thread Starter
Buckeyepsd's Avatar
Quoted: 3 Post(s)
Sorry for the ignorance, whats the 50 cent mod?
post #5 of 5 Old 11-15-2013, 04:04 PM
Quoted: 861 Post(s)
