01 7.3 Rough idle no power LOTS OF CODES!! - Ford Powerstroke Diesel Forum
Old 08-06-2008, 11:17 AM
Ok the other day I was backing up a hill and my service engine soon light came on and my truck started idling really rough and I had NO power..I got on level ground and it went away..but Now Its acting up pretty constant..I changed fuel filter and am going to replace air filter...I got it scanned and the code came up P1316,P0472,P0603,P0273,and P1295....I am soo in the dark and am really concerned because my local dealership told me that one of the codes that came up usually means the motor is shot or something seriuosely wrong internally..HELP!!!!
Old 08-06-2008, 11:48 AM
Anyone!?? I am out my work truck now and dont want to take it to the dealer and get robbed for something little
Old 08-06-2008, 11:57 AM
Desert Shield/Storm Vet
Its possible your under the valve cover harness is coming loose. Hopefully a tech will see your post
Old 08-06-2008, 12:24 PM
Did you epty the fuel water seperator. Sometimes if you dont empty the water it will contaminate fuel you said you were backing up hill which could have brought the water off the bottom.
Old 08-06-2008, 02:33 PM
SyN SyN is offline
Lubrication Addict
I agree with vital: Replace both sides if you end up having to replace. I used to have a url within my favorites, of all the most popular codes that are thrown. I think there is a sticky at the dieselstop.com. That has these codes.
Look here----->Welcome to guzzle's Diagnostic Trouble Code list Web Page
Old 08-11-2008, 02:09 PM
I tryed both harnesses and they are both good. It went away for about two days and now its back with a vengence! I cant figure it out..I am trying not to take it to the dealership and get rapped!!! HELP
Old 08-11-2008, 02:15 PM
You pulled the valve covers off and actually checked them? Sometimes they work themselves loose. If they are good and not comming loose you probobly should have someone with a scanner run a buzz test, contribution test for you.
Old 08-11-2008, 02:49 PM
I can tell you from experience that sometimes the valve cover harness will check out electrically but is actually bad. I was having similar problems but everytime I checked my harness everything was ok. I went ahead and replaced it on a hunch and luckily it fixed the problem.
Old 08-11-2008, 06:32 PM
Send a message via Yahoo to skoalcowboy22
Yeah to me you wiggling them to check them might have seated a wire thats when it went away and now its working itself back out. Go ahead and change the harnesses. There cheap and better to do now than once you get towed home
