HELP sinking feeling in gut after running cylinder contribution test! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-05-2013, 10:01 AM Thread Starter
So just when I thought I was done wrenching for a while I ran a cylinder contribution test on my 02 7.3 with 129000 plus a change in rotational velocity test and here is what I got. Please help decipher.
Cylinder contribution test:
P0269 Cylinder 3 Injector contribution circuit/balance fault
P0284 Cylinder 8 " " "
When I replaced my wiring harness and glow plugs a week or so ago after putting the valve covers on I ohmed out the pins to the injectors before plugging back in the UVCH on the top side of the engine and all was good on communication.
I then checked the rotational velocity check and Cylinder three was around 3.5 to 4.2 and Cylinder 8 was around 4.5-5.4 where all others were right near zero like they are supposed to be.
I have read that the grey CPS which in mine is brand new from ford can throw off number 8 readings but I don't know if this is true. I am not blowing smoke on startup or while running and I am getting good mileage and from what I can tell (first powerstroke) the only running sound that is a little off to me is if I am under very light acceleration then it seems as though the "flutter" is a little off sequence but then again I have no cat and straight pipes. Quietest straight pipes I have ever heard by the way.
2002 F250 Good Old 7.3
126000 miles and counting
Gerald Ford (14 July 1913 – 26 December 2006)
"A government big enough to give you everything you want is a government big enough to take from you everything you have. "
Tdog77 is offline
post #2 of 3 Old 11-06-2013, 05:14 AM Thread Starter
I got this from Swamps site last night and am going with it....essentially I am going to ignore this one and if the issue gets worse I will run a compression test and bypass the dam AE program and possible CPS interference since I cannot get a black sensor anymore.
"Cylinder Contribution Tests can often flag cylinders #1 & #8, or #3 & #8 as both failing the CCT. Anytime #1 & #8 are paired as hacing balance faults...especially on 99-03 trucks, this may indicate a fuel delivery problem (pressure, contamination, etc). The pairing of #3&#8 are “companion” cylinders...so an internal or external engine balance problem will often show up as 3&8 cyls failing balance tests. We have also seen a CPS (camshaft position sensor) show false codes related to cyls 3&8...however if the engine runs normally, then it is our recommendation to simply ignore these phantom codes."
Tdog77 is offline
post #3 of 3 Old 11-06-2013, 05:55 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
NoRalPh is offline
