Broken Turbo Shaft...HELP - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-01-2013, 03:53 AM Thread Starter
ColoradoDoug's Avatar
I tried to take my compressor wheel off to install a wicked wheel and SNAP. The shaft broke. I need to get this vehicle back on the road. Does the shaft need to be pressed out and a new shaft pressed in? What about the bearings? Is there a how to writeup or instructions floating around on the web that someone can direct me to.
I can't have this down for another week. Anyone know where along the front range of Colorado, I can get a shaft with the exhaust wheel installed?
Thanks
'03 Eddie Bauer 4x4 Excursion 6.0 Diesel, CCV mod, upgraded turbo drain, blue spring fpr kit, 6.4 banjo bolts, zoodad, v code front springs and modified b code rear springs, Bilsteins, Hellwig rear swaybar, '08 rear diff cover, 4x2 liftgate struts, 285 Michelin LTX A/T2's, tinted windows, DVD, XM, GPS
ColoradoDoug is offline
post #2 of 3 Old 11-01-2013, 06:33 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
Find another Turbo, welding is not possible, disassembley and shaft replacement are possible but, if you're in a hurry I wouldn't bother learning something like this (it's not simple) just find a turbo (new or used) and be done...
NoRalPh is offline
post #3 of 3 Old 11-01-2013, 06:53 AM Thread Starter
I have no intention of welding on it. I just like the cheaper alternative of replacing the shaft and not the entire turbo. I did see a writeup on a turbo rebuild. If the shaft had no play, can I reinstall the components inside, or once pulled apart, should be replaced? The local warehouse for Garrett has no shafts and no rebuild kits. I did see a shaft on ebay though.
