urgent help please, truck died, suspect PCM - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-31-2013, 09:17 PM Thread Starter
Hi,
Hoping for some help. Driving the truck in my signature, it died and would not start. New batteries a month ago, new alternator six weeks ago. No recent codes or problems... has been running great.
Now, the dash displays ------------ in the green LCD, then when key on, "Check Gauges" and many lights. No clicking of relays or injectors, no fuel pump, just nothing. No crank, glow plug light and wrench light stay on.
Edge CTS cannot display any data, and SCT programmer cannot retrieve any vehicle info (no VIN, no Strategy) or codes (error message cannot read codes).
Loosened the 3 connectors at the PCM and reconnected. Disconnected negative battery cables for a minute, then reconnected. No change.
What next?
If I need a PCM, what do I need to know?
The truck had a tune installed, and I have the stock file and the tuner's file saved on my computer, but if I replace the PCM, will my SCT work with it again, or do I need to do something special with it like sending it back to SCT?
Thanks for any help.
p.s. I was supposed to be leaving tomorrow morning for a week of work :>(
2006 F250 ext cab, short box, 4x4 auto
ARP studs, BPD EGR cooler, Ford oil cooler, HPOP and turbo line updates (by Bernhausen @ 219K Kms)
BPD billet water pump, AFE CAC pipe
Eng. strategy VXCF9H7; TW Extreme tune
4" SS Magnaflow turbo back w/ muff & hi flow cat.
Edge CTS monitor w/ EGT
CAT EC-1 coolant w/ bypass filter
stock air intake w/ shielded Zoodad
3.73 axles, 275/70R18 BFG A/Ts
To do: injectors, Snow Stage 2 water injection, blue spring, fuel press sensor
metric convert
freecanadian is offline
post #2 of 5 Old 10-31-2013, 09:50 PM
sargar's Avatar
Have you covered the basics like fuses, all 4 battery connections, etc?
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #3 of 5 Old 10-31-2013, 10:05 PM Thread Starter
Yes, power is good, connections are tight and clean (and new batteries). Power windows, radio, lights, and alarm work (I set it off when I reconnected the batteries and opened door). Seems like PCM is not connected because no VIN communication between SCT or Edge CTS unit. Even with some power, there should be communication there.
I blew a fuse 2 weeks ago by a short in a 12v power plug in cord, and it shut down my Edge CTS because no power to the OBD II port, but changed the fuse and it came back on. Now, the CTS has power, but cannot identify the truck at all and so no gauges even come up on it after the truck died while driving it today.
I have tried to read other posts about PCM, and many have been intermittent problems, FICM related, or codes, but I can't even read FICM voltage on CTS or pull codes any more.
Thanks.
metric convert
post #4 of 5 Old 11-05-2013, 04:43 AM Thread Starter
Got it fixed. It was blown fuse #22 (Engine Control). Not known why it blew, but first and only time. Time to install those SmartFuse fuses that glow so it's easier than pulling every one of them to have a look.
metric convert
post #5 of 5 Old 01-03-2014, 11:01 AM Thread Starter
update; cause of blown fuse
Hi, I thought I would update this just in case it might help anyone else. I had the truck in today for a check up, and it was found that the fan clutch is not working. The shop said this would be likely cause of blown fuse for PCM, which only happened on more time since my last post here.
It has been cool enough during the past few months that the cooling fan may not have been needed, except for the two times that the fuse blew. The fan clutch was replaced several months ago (late summer / early fall) with a near new (used) unit which apparently did not last very long.
So, now I will be looking to source a new fan clutch and get it installed.
Happy New Year to everyone on the ORG!
metric convert
