2006 6.0 fuel pressure issues - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-26-2013, 02:14 PM Thread Starter
Mauch2's Avatar
Ok im needing help, my truck runs fine when im driving conservatively but when i go WOT around 3000rpm it begins to spudder, i used to be able to light up the tires no problem and now i cant. Ford dealership says i might have a fuel leak and then something about the high pressure fuel pump, the problem is i dont have $500+ just to "figure" out whats wrong with it before i spend money to actually fix it. Please i need something here to get me started
Info on the truck
-2006 6.0L
-100,000miles
-SCT Flash Ford Programmer
-Straight pipe stacks
-Blue Spring upgrade
Mauch2 is offline
post #2 of 9 Old 10-26-2013, 02:33 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 53 Post(s)
Feedback Score: 7 reviews
OEM fuel filters? replace recently?
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #3 of 9 Old 10-26-2013, 02:35 PM Thread Starter
Mauch2's Avatar
havent replaced them and yes still running stock filter
Mauch2 is offline
post #4 of 9 Old 10-26-2013, 02:37 PM
Quoted: 53 Post(s)
i would start with replace your filters (both). use motorcraft or racor.
post #5 of 9 Old 10-26-2013, 02:39 PM Thread Starter
Mauch2's Avatar
ok ill start there, i forgot to mention that my fuel pressure fluctuates when im at idle, bounces from 50-65psi, before any of this started after the blue spring i was running around 65-70psi relatively steady
Mauch2 is offline
post #6 of 9 Old 10-27-2013, 09:47 AM Thread Starter
Mauch2's Avatar
wow huge improvement, i never thought that just the fuel filters could choke the whole truck down like that, thanks a bunch man problem solved
Mauch2 is offline
post #7 of 9 Old 10-27-2013, 10:05 AM
kafleming19's Avatar
Quoted: 740 Post(s)
Have you recently or do you run your tank fairly low? Over last summer I ran it low a couple times and after that my pump was fine while normal driving but if I went past 1/2 throttle while tuned the pressure would drop below 40 and would start to sputter. Tried filters and blue spring with no change.... Put a new fuel pump in and now it's good. I think "starving" the pump(making it work harder and/or sucking air) made it weak... If I ran stock programming it ran fine no matter how I drove. But tuned it would sputter. I would try the filters first and also return to stock and test it out. If it runs fine on stock my bet is on your fuel pump.
Kily AKA Lt. Axe
kafleming19 is offline
post #8 of 9 Old 10-27-2013, 01:31 PM
Quoted: 53 Post(s)
Glad it was an easy fix
post #9 of 9 Old 10-27-2013, 05:33 PM
Help with my 2004
[QUOTE]hello I have a 2004 6.0 when I pull up to a red light and go to take off the truck won't go I kill the truck recrank it and it goes then if I stop and kill it it does not want to crank takes several min and try's then it will start please help
jfGreen is offline
