No heater - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-20-2013, 08:09 AM Thread Starter
No heater
I have a '06 F350 Lariat psd 4" exhaust and intake. Egr delete oil stand pipes blue spring mod. My problem is when I am on the throttle I have heat coming out of my vents. When I let off the throttle or at an idle there is no heat just cold air? I have put a scan tool on it and it shows no codes in the HVAC system, or the motor. Any help would be great.
bullriding383 is offline
post #2 of 2 Old 10-20-2013, 09:13 AM Thread Starter
If I am thinking right this would not be a vac issue, if I were on the throttle I should loose heat an at an idle I should have heat, right? It looses heat in what ever position you have the vent in, defrost, face, face and floor etc..
