6.0 no power HELP - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-18-2013, 12:31 PM Thread Starter
Exclamation 6.0 no power HELP
Ok, it is a 2005 6.0 4x4 with egr delete. Yesterday I drove the truck about 75 miles to a job site truck ran great, was on site for about 45 mins. I get about a mile down the road, truck has no power. I stop at auto store buy both fuel filter change them out, no change. I get on the highwAy no power, turbo has boost pressure and can hear the turbo, truck will not pull its weight in 6th gear, I down shift to 5 the gear truck would hardly run 50 mph. So pull over as soon as the clutch is disengaged it dies, but starts right back up. I let idle has a very slight miss, so I get back in try to take off and she starts bucking, had to use granny gear to get going. I drive her home in 4th the 75 mile trip, she can't pull on hills, has no black smoke, nothing but it running like crap. Called around to diesel shops one said fuel pump, the next said ipr valve, the 3rd said a injector was out. HELP!!! Can someone lead in the right direction.
mholmes49 is offline
post #2 of 9 Old 10-18-2013, 12:52 PM
sprksonu's Avatar
It sounds like the symptoms my truck had when my fuel injector control wiring harness went bad
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 9 Old 10-18-2013, 05:37 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
I would lean toward a fuel problem for the simple fact it run like sh1t without smoking. You need to put a monitor on her to find out if it is an ipr valve, ficm, or anything engine related. I would put a gauge on your fuel regulator test port and see if you are getting the correct fuel pressure I'm not exactly sure what the desired fuel pressure is maybe 38psi or more? Stock application is about 42psi and blue spring mod gets about 60psi. I'm not exactly sure but you could be overworking your injectors causing the truck to run rough. Just my 2 cents
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #4 of 9 Old 10-20-2013, 06:33 PM Thread Starter
Got her fixed, was ipr valve covered with light green rubber. Anyone got ideas where the rubber came from?
post #5 of 9 Old 10-21-2013, 05:06 PM
where is the ipr valve located?
mkeevo is offline
post #6 of 9 Old 10-21-2013, 05:56 PM Thread Starter
Top of the hpop and behind the turbo, if you need to get to it, it simple all you need to do is unbolt turbo and pull it out. That is all you have to move to get to it. If you move more then that you are wasting time
post #7 of 9 Old 10-21-2013, 06:16 PM
Remove the turbo. Great
mkeevo is offline
post #8 of 9 Old 10-21-2013, 09:36 PM Thread Starter
It's pretty easy two oil tube bolts on top, three Turbo base bolts and the intercooler tubes
post #9 of 9 Old 10-22-2013, 11:59 AM
Use an IPR socket and get to it by just removing degas bottle.
Mark Smith
04 F250
58V FICM w/80ATLAS
SCT TUNA
MarkSmith is offline
