Late 1999 F250 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-16-2013, 12:25 PM Thread Starter
Late 1999 F250
Hey guys, hope all is well. I drove my late 1999 F250 (95,000 miles) truck to work yesterday, went to leave and had a no start issue. Over this past weekend, I noticed that there were a couple times when I had to crank it over a second time for it to start but I didn't really think twice about it because it had sat for about 3 weeks or so. My first step to diagnose was to remove the TS perf 6 position from the PCM. I did that and then the truck would still not start, cranks good but no start. I checked all of my connectors, wiring and everything seems to be connected. All of the fuses are good. I'm not really sure where to start next.
philly2430 is offline
post #2 of 2 Old 10-16-2013, 03:14 PM Thread Starter
After cranking it over too many times, the batteries were kind of dead so I jump started the truck and it eventually started. I let it run for a about ten minutes or so and tried to restart it and it would not start. Jumped it again, did some playing around with a volt meter and found that there was a voltage drop between the positive terminal and the connector on one of the batteries. When I took a closer look at all of my terminals/connectors, i noticed they all needed to be cleaned. After I cleaned them, problem solved.
