ATS turbo housing not lining up with stock intake? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 10-12-2013, 12:21 PM Thread Starter
Premium Starfish Member
AzPatMan's Avatar
Quoted: 33 Post(s)
ATS turbo housing not lining up with stock intake? (FIXED!)
I've got a bit of a situation happening here.
I've been fighting this turbo swap now for about 2 hours and can't figure this out.
The new turbo has an ATS ported 4in housing - and for the life of me, I cannot get the intake spider to line up to the turbo horn.
I don't want to take the turbo back out for something that should be so menial...
Am I missing something? I need to get this back up and running by tonight.
here's a pic, thanks for any help
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
post #2 of 14 Old 10-12-2013, 12:28 PM
CSIPSD's Avatar
And your sitting on the pedistal correctly? Looks like the boots are loose for the intake Y?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 14 Old 10-12-2013, 12:29 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 898 Post(s)
Feedback Score: 6 reviews
That sucks Patrick. Hope you get it figure out bud and wish I could be of some help, but I have never worked with the turbo on a 7.3.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is online now
post #4 of 14 Old 10-12-2013, 12:29 PM
CSIPSD's Avatar
Its hard to tell from just one picture but it looks like you just need to push it down and back?
Can you take any other pictures from a bit further back?
Joe
CSIPSD is offline
post #5 of 14 Old 10-12-2013, 12:46 PM Thread Starter
AzPatMan's Avatar
Quoted: 33 Post(s)
the pedestal itself was not taken out , only the turbo.
the new turbo is in, and seated on the pedestal fine - and even managed to get the up-pipe collector lined up, and the downpipe and got the band clamps back on. Had no issues there.
It just seems like the ATS horn is almost 1/8 longer than the stock.
And yes - I have the boots loose for the intake because I had to take the intake out since I have the EX, it sits back a bit more than the F250.
so to get the turbo out, I had to pull the spider.
But yes - I still have the intake boots loose because I'm trying to finagle intake to mate up to the horn. the bottom seems to mate up, but I can't seem to get the top fully mated.
AzPatMan is offline
post #6 of 14 Old 10-12-2013, 12:50 PM
CSIPSD's Avatar
Hum... nothing sits different between an Excursion and a pickup...
Just saying.
Beyond that I would say loosen the turbo from the pedistal... Did you mention you swapped the entire turbo, not just installed a housing? are you sure its not a 38R with a clockable housing?
Joe
CSIPSD is offline
post #7 of 14 Old 10-12-2013, 01:13 PM Thread Starter
AzPatMan's Avatar
Quoted: 33 Post(s)
So went ahead and pulled the intake boots off, now even more WTF's...
Only way it seats to the horn now. But it's in direct contact with the drives side plenum, and i've got a huge - misalligned gap to the drivers side plenum.
this is crazy.
drivers side, showing it mated (without the boots.)
drivers side pic of the misalignment and gap
drivers side - close up.
Passenger side - spider is in direct contact of the plenum
AzPatMan is offline
post #8 of 14 Old 10-12-2013, 01:37 PM
CSIPSD's Avatar
IS THE HOUSING CLOCKABLE???
Did you swap an entire turbo or just the housing?
Joe
CSIPSD is offline
post #9 of 14 Old 10-12-2013, 01:43 PM Thread Starter
AzPatMan's Avatar
Quoted: 33 Post(s)
I think I found part of the problem.
I looked at the 'stock' housing from the turbo I took off - "THERE IS!" a slight angle of the horn towards the drivers side.
The ATS 'does not' have this - it is a straight out. I busted out the straight edge, and placed it against back-plate the snail connects too. on the stock, there is a about a 1/4 inch gap.
on the ATS - the edge of the horn is below or past the back plate - which is causing my misalignment. <sigh> now I need to figure out what to do.
AzPatMan is offline
post #10 of 14 Old 10-12-2013, 01:45 PM Thread Starter
AzPatMan's Avatar
Quoted: 33 Post(s)
No, the housing is not clockable. It has the internal alignment for the GTP-38 housing.
I swapped the entire turbo (short of the pedestal)
AzPatMan is offline
