Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 07-02-2008, 05:10 PM
tougas tougas is offline
7.3 battery light on, not charging batteries...help
Out of the blue last week my battery light came on while on the highway. the voltage meter went high, around 16 or 17. the other day it started to drop, to the edge of normal, then finally until the batteries were flat out dead. the batteries, starter, alternator are all new within 4 months. we changed the alternator out again, because it has a lifetime warranty, and it still didn't help the problem. we checked the ground cable under the engine and it is tight, and the terminals, and all are tight. any suggestions? anyone have the same problem? thanks a lot guys and by the way i need my truck for work tomorrow! thanks
Old 07-02-2008, 05:19 PM
bigcountrysg bigcountrysg is offline
Countryboy Mechanic
Pull batteries out. Take them to an autoparts store have them tested. Your batteries may not be accepting the charge from the alternator.
Old 07-02-2008, 08:35 PM
blizzardwarrior7 blizzardwarrior7 is offline
Send a message via AIM to blizzardwarrior7
Ill second that.
Old 07-02-2008, 09:24 PM
Cj Ford Cj Ford is offline
a bad battery will kill the second battery... you may have 1 bad one.. if you do
Replace both at the same time with matching batteries
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
