94 PSD No start after starter replacement - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-25-2013, 09:48 AM Thread Starter
Hey guys, replaced the starter in my truck and when I did I failed to disconnect the batteries before hand and arc'd the hot & ground when removing the old starter. Now when I get in and turn the key I have a wait o start light, the interior lights and deck ire up but when I turn the key she just cranks. I blew maxi fuse 8/22 so I replaced the two fuses and disconnected the fuel bowl heater with no luck. Where should I go from here? I'm assuming my rush caused me to fry either the IDM or PCM when I sparked the old starter
1995 F350 CCLB
7.3L Powerstroke
ZF-5 w/ South Bend 1944-5OK
Baby Swamps
PDR Diesel Super 66 1.0 Housing/Billet Wheel
TS 6 Position
6.0L Intercooler
PDR Diesel Intercooler Piping/Boots
Intake
3in DP 4in SS exhaust
US Gear Overdrive
Pacbrake
310KM (193MI)
matt-jenkins is offline
post #2 of 8 Old 09-25-2013, 09:59 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
This may help but it definitely sounds like something is fried as long as all your fuses are good Diagnosing a 7.3 no start
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 8 Old 09-25-2013, 10:06 AM
broncomitch's Avatar
clean the terminal ends on the starter,cable,battery?
broncomitch is offline
post #4 of 8 Old 09-25-2013, 10:15 AM Thread Starter
Had a look at the link posted, nothing terribly relivent to my issue but I appriciate you sharing, the cables and terminals are in good shape, I'm
Convinced its a fuse, fusable link or a fried component. Where are the fusable links on these trucks, and would a fried PCM relay cause any of these symptoms?
post #5 of 8 Old 09-25-2013, 12:34 PM Thread Starter
Fusable Links on passenger inside fender attached to starter relay appear all good, when i first replaced maxi fuse #22 I was getting power to the PCM and my Edge CS would connect and display the gauges, now the edge will not connect to the PCM, no WTS light but the Tach does move when cranking.
post #6 of 8 Old 09-25-2013, 05:33 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
Any chance you can get a code reader preferably an AE to check things out? If the scanner won't connect , most likely a PCM problem or your tuner is fried . Can you remove the tuner and see what happens. In the future ,always disconnect the batteries, PCM's are not cheap.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #7 of 8 Old 09-25-2013, 05:49 PM Thread Starter
Unplugged the chip and no change, I am using a Snap on as well as my edge insight code reader. What would a new or reman PCM cost?
1995 F350 CCLB
7.3L Powerstroke
Baby Swamps
TS 6 Position
6.0L Intercooler
Intake
US Gear Overdrive
Pacbrake
310KM (193MI)
post #8 of 8 Old 09-26-2013, 06:29 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
$350 to $450 with your unit as a core
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
Isspro 3 Gauge Pod
Banks Big Head
298K
