7.3 will not start
I have a 2000 7.3 F250 that suddenly will not start. Batt's are new and replaced starter. When I turn the key everything cycles like it should bur I get nothing when I turn the key. Like I said I tried putting a new starter in and that was a little spendy any ideas would be great.
have you changed the Cam Position Sensor? if not, go to your local Ford dealer, there is a recall on that part for 1997's and newer. it's free to you.
I have replaced the cam position sensor already! Thanks though.
Is it turning over
No, When I turn the key the glow plug indicator activates and cycles. then I get nothing when I turn the key.
well if its not turning over then maybe your not getting power to the starter?
Correct, Do these have nutral safety swithches that go bad or is there a cylanoid relay?
you know you could of got a bad cps ford is giving out crap replacements as well.
When it went bad before the motor would still turn over. Would the cps not alow the motor to actually turn over?
ive heard it will lock the motor and not turn over, that didnt happen to mine , but my friends "x" wouldnt move he had to have it towed to ford.
