Big *** knock in 6ltr - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-24-2013, 02:40 AM Thread Starter
I've had the truck for approx. two months. Prior to, started great no problems . Left the truck sitting for the last couple of days , Started up yesterday morning was approx. 48 F outside , took about 5 -6 cranks to turn over , then a huge knock for about 20 sec's then back to running fairly smoothly.. this is a first time experience with this knock.. any input?
2006 f350 6ltr 234K
dipstic is offline
post #2 of 5 Old 09-24-2013, 02:46 AM
usnavyad's Avatar
Feedback Score: 3 reviews
Hmmm that could be a lot of things any codes smoke anything ?
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #3 of 5 Old 09-24-2013, 02:49 AM Thread Starter
no codes,, I'll check this morning when I start it up for smoke and if the knock persists. its a little early here 4;49am,. don't think the neighbor would appreciate me.. get back to you
thnx
dipstic is offline
post #4 of 5 Old 09-24-2013, 03:23 AM
ADMIN AND TECH
SCUFFY828's Avatar
id guess a bad injector or two , need to start by checking for codes , check ficm voltages and then have a legitimate cylinder contribution test run when engine is cold to verify which injector it is
ITS STOCK
SCUFFY828 is offline
post #5 of 5 Old 09-24-2013, 05:08 AM
usnavyad's Avatar
Agreed^^^^^^^
GPDA's other shawn
usnavyad is offline
