97 powerstroke dead injector - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-23-2013, 07:12 PM Thread Starter
I just recently replaced my valve cover gaskets the wiring harness for the glow plugs and injectors and new pigtails on the outside that plug into the valve cover gaskets the truck ran fine before just needed glowplugs but did it all just because I had it all apart and now the injector for cyclinder #2 isn't working. With the valve cover off on the driver side I unplugged each injector one by one and when I did the first one there was no change the way the truck was running and no oil was coming out of the spout.
Just wondering if anyone had an idea on what to check I haven't checked the ohms because I don't really know how to do that.
Arctic_rider83 is offline
post #2 of 3 Old 09-25-2013, 07:01 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
Change out the injector , its dead or swap it with the injector next to it and see what happens
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 3 Old 09-25-2013, 07:08 PM Thread Starter
Ok thank you that's what I was going to do or take the solenoid off and switch it with one to see if its bad. I did just ohm everything out and it all seemed to check out ok. Not sure what that means if it means the wiring is all ok or what
