03 6.0L Cold miss/No codes - Ford Powerstroke Diesel Forum
Old 06-20-2008, 01:15 PM
Cranks/Starts good, feels like one or more cylinders gone. Cycling key (longer glow plug time) no change. No codes present. Replaced driver side glow plugs. No change. At normal operating temp. runs great, lots of power. Have factory manuels but not much info on driveability if no codes present. Problem only exsists when sitting for more than ~8hrs regaurdless of outside temp. Where should I test next, or is this a common issue? Thanks. Keith.
Old 06-20-2008, 01:20 PM
<-Day Of Fail now SOLD
I wish feel ya, I'm having he same porblem Pretty soon I'm gonna fix that sticking injector the fun way Its called SCT custom tunes. Best of luck to you.
Old 06-20-2008, 01:21 PM
I almost forgot
Old 06-20-2008, 01:35 PM
Hey thanks for the welcome and quick reply.....Ok what is SCT custome tunes?
Old 06-20-2008, 01:39 PM
It's as far as I know the best tuner for the 6.0, there are several dealers here that offer custom tunes that will give you better mpg and tons of peddel response
Old 06-20-2008, 01:46 PM
I have the banks power pda and intercooler. Great mileage, pleanty of power, no problems. This just came up.
Old 06-20-2008, 02:03 PM
I would think about getting rid of your banks stuff, and come to the other side of rolling the coal power Where are you froM?? Maybe a tech in your area will chim in
Old 06-20-2008, 02:11 PM
have you had your truck re-flashed with the newest flash ......mine did the same i would start in the morning and it would sound like bowling balls in there and i would have no power untill it wormed up ......but i got it flashed at the dealer and its great now
Old 06-20-2008, 03:38 PM
Truck was reflashed from a recall about two years ago.I did not have the problem until recently.
Old 06-20-2008, 03:39 PM
Joliet Il area.
