6.0 intercooler tube blowing off turbo!!! - Ford Powerstroke Diesel Forum
Old 06-19-2008, 11:53 AM
Exclamation 6.0 intercooler tube blowing off turbo!!!
what could cause this to happen the silicone hose pops off at high rpm but only when under a load???
Old 06-19-2008, 04:47 PM
Slacker
Feedback Score: 4 reviews
Welcome to the ORG! Sounds like your silicon boot is oil soaked. You might wanna try to wipe it down real good and then spray it with hair spray. After it gets tacky, put it back together and it should help pretty good. If not, you will have to replace it. It happens because oil is recirculated through your turbo via the CrankCase Vent; do the CCV mod and reroute the CCV, so this doesn't continue to happen.
Old 06-19-2008, 05:09 PM
have you ever took it off before? I had this problem when i removed mine when i painted them. I had this happen to me a few times. I had a buddy help me when tightning it back down. He pushed hard on the pipe while i tighning it down. I did it myself and actually saw the pipe walking out of the boot while tightning it down. try that, hope it works out for you!
Old 06-20-2008, 11:50 AM
thanks alot i will try that tonite and let u guys know if it works, and yes i took it off to install the turboback exaust
