99' 7.3 excessive oil consumption
My truck is using 1 gal. of oil every 400 mi. no smoke, no oil on either side of the turbo. runs and starts good otherwise. the injectors have been tested and are good. sent them to a diesel shop in Florida
Oil
I would say to have your injectors removed and pressure tested. Probably have 2 or more that need to be replaced.
I'm having the same problem with mine...Have you figured anything out yet?
PM sent. Let me know.
there is ony one way to use that much oil and that is thru the internals in the injectors , no external leaks , there is no other way , i have seen injectors that were either pressure tested incorrectly or were tested correctly and still had a problem, the pressure test that the injectors are put thru are for the most part fairly accurate , but if i hadnt seen it for myself wouldnt have believed it either , but had a truck 8 months ago that was using similiar oil, all injectors tested good , replaced injectors and problem gone , this truck was an 03 7.3 with only 42,000 miles on it , i think youll find that the injectors will be where the problem is
