7.3 wont start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-19-2013, 07:48 PM Thread Starter
7.3 wont start
I am trying to help my brother out but am out of town so dont have the ability to hook up my AE for a couple weeks till I return. He has had previous starting issues with the truck and has gotten worse over time now it takes cranking till the batteries are almost dead to get it to start, it starts smoking white after about 20 seconds of cranking. The last time he had issues they swaped injectors with another set of used ones and replaced all glow plugs which helped with starting but still required extended cranking. They performed a compression test and dont recall exact numbers now but believe one was low 200s and rest were mid 3s.
So far he has replaced batteries, starter, icp sensor, spare IDM (previous to this the truck would set a SEL light when under acceleration but never any codes were stored), and cps. He had his edge hooked up and when cranking he gets a the ICP less/greater than expected and when cleared it comes right back when cranking.
He doesnt have the time to wait till I can get back and dont want to see him throw parts at the truck since it is a farm truck with 300k on it. My thinking is either injectors or the low compression in one cylinder causing the issues. Any advice on what he should be checking next before buying more parts, I suggested removing the valve covers with it running to watch injectors for oil. Would one cylinder with low compression cause that much of a hard start?
Could this be an issue with the IPR?
Thanks
cory99 is offline
post #2 of 4 Old 09-19-2013, 07:58 PM
alaskan155's Avatar
Quoted: 60 Post(s)
when was the fuel pickup last replaced? can it go below a quarter tank?
i know the pickup valve on these trucks has a check valve maybe it broke/went bad? seen a few post on it here and there, if the check valve is broke the fuel could be draining back causing air to be in the line
just a check thought, any codes before you replace anything?(oriellies will scan it for free)
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 4 Old 09-20-2013, 06:50 PM Thread Starter
Some more info he tried a new ipr today and still no changes. He did a cojpression check and all are around 300 with one being 210. I know the numbers arent great but would it be that hard to start with only one really bad hole or would it likely be injectors?
cory99 is offline
post #4 of 4 Old 09-25-2013, 07:44 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 4 Post(s)
Worn injectors make for hard starts , low compression , bad glow plugs , aren't going to help.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
