92 7.3 won't start - Ford Powerstroke Diesel Forum
Old 06-11-2008, 04:13 PM
Question 92 7.3 won't start
hey guys new to the forum but not new to ford trucks i run a garage door business and all of my trucks are fords with lots of miles and still running stong but enough about me i just wanted to tap into you all's wealth of knowledge i have a 92 7.3 that will not start. started out just doing it when it was hot or run for quite awhile once you shut it off you had to wait about an hour and then it would start back. i'll tell you what i know so far i have fuel preesure at the fuel filter when i crank it. but i cracked the injector lines and i have no fuel there please help
Old 06-12-2008, 02:09 PM
any help apreciated
Old 06-12-2008, 02:15 PM
BIG TRUCK, SMALL DRIVER
Check the fuel cut off solenoid on the injector pump. It could also be a failing injector pump.
Welcome to the ORG.!
Old 06-12-2008, 02:38 PM
When it wont start pour some cool water, NOT ICE COLD water on the injection pump to cool it down. IF it starts, it's time for a injection pump rebuild.
Old 06-12-2008, 07:28 PM
the solenoid on top off the pump is not clicking when i turn the key on anyway to bypass it or wire it straight just to see if that is the problem and where can i find one can't seem to find one localy. injector pump rebuild if that is the problem. i'm kind of new to this diesel stuff what kind of $$$ are we talking about
Old 06-12-2008, 07:44 PM
ADMIN AND TECH
injection pump, injection pump, injection pump, lol, you can waste alot of time trying to figure out whats wrong , but if you have base fuel pressure put a injection pump on it
Old 06-13-2008, 12:08 PM
will a rebuild be suffice or should i get a new and any ideas on the best place to find one. nice truck scuffy bet that 90g aux. tank cost a pretty penny to fill.
Old 06-13-2008, 12:53 PM
Rebuilds are about all you'll find, new pumps are not made any more. I've heard good things from Hectorwithinjectors on Ebay or Taylor Diesel Group shop.dieselpage.com
Old 06-13-2008, 03:38 PM
thanks for the info I found new ones at dieselspecialists.org for around $450
Old 06-17-2008, 12:36 PM
just wanted to take a minute to thank you guys for all your help. it was indeed the injector pump still pouring coldwater over it when it gets hot until i get my new (rebuilt) pump in. that water trick has saved my life. i know it's not technically a powerstroke but i still love my old workhorse.
