1997 7.3 wont turn over - Ford Powerstroke Diesel Forum
Old 06-11-2008, 09:07 AM
Unhappy 1997 7.3 wont turn over
replaced batteries,noticed Glow plug relay terminal was cracking at base replaced . wait for start engine light, turn key clicking coming from Glow plug relay. help new to forum
Old 06-11-2008, 09:15 AM
Shaking the Bush Boss
check the mega fuses under the hood. if the fuel heater element has broke loose from its mounts inside the bowl, ti will short and blow the fuse....no start
Old 06-11-2008, 11:27 AM
thanks for th advise will ck tonight
Old 06-11-2008, 11:31 AM
International Threat
Any codes?
Does it click once and then stop, does it click like it doesn't have enough power? Do the relays flicker and pop like crazy while cranking?
Let us know...
Old 06-11-2008, 11:33 AM
a truck
I'm having the same problem right now so i'm just listening in for the advice given
Old 06-11-2008, 11:38 AM
it clicks then stops
Old 06-11-2008, 11:54 AM
Does it just click once? Then all the dash lights go out, but come back on when turn it back to accessories?
Old 06-11-2008, 12:06 PM
yes clicks lights go out then back on accessories
Old 06-12-2008, 06:06 AM
fuses all good, had batteries load tested check out okay, shop said ck starter relay on fender,i turn key on wait for engine light clicks once then nothing click coming from gpr
Old 06-16-2008, 08:29 AM
problem solved bad connections on starter pulled starter wire brushed starts now
