97 engine missing - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-13-2013, 05:01 PM Thread Starter
Unhappy 97 engine missing
I have a 97 powerstroke with 268000 miles on it it recently started randomly missing now it has gotten so bad I cant drive it I have checked fuel pressure it stays between 50-55, map signal is in specs, no codes either, icp at idle is 578 and reading 13% on scanner I ran a cylinder contribution test when it first started and number 7 failed I replaced that injector. last week I ran a cylinder contribution test 3 time the first time number 1,2,3 cyl failed, the second time 1,2,7 cyl failed, the the third time just 1 and 2 cyl failed the truck is a automatic so it is not the flywheel cuasing false reading what else do I need to check before condemning these other injectors.neeed help Matt
a70olds is offline
post #2 of 4 Old 09-13-2013, 08:45 PM
JustinOOO9's Avatar
Quoted: 421 Post(s)
Garage
so my 6.0 has whats called a ficm (fuel injection control module) and when the volts get low it can throw contribution codes etc... does the 7.3 have a similar component you can check?
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes,
currently-1999 F250 SBRB 4X4 First 7.3, 6.0 trans cooler made my muffler fall off
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 4 Old 09-14-2013, 04:43 AM Thread Starter
I believe it has what is called a IDM (injector driver module) basically similier but I don't know how to diagnos that thing and not setting any codes except when u run a cyl. contribution test with scanner.
a70olds is offline
post #4 of 4 Old 09-18-2013, 05:21 PM Thread Starter
ok I ran a compression test on all 8 cyl engine cold all cylinders were within 10 psi of eack other from 350 to 340, whats is everyone input on this, the truck has 268000 miles on it should I buy a set of injectors or pull the motor and build it.
a70olds is offline
