Hard Starting - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-05-2013, 08:32 PM Thread Starter
Unhappy Hard Starting
Hello , I have a 06 F350 6.0 . 184000 Miles, use Roettla oil . I've owned it for about 1 month , during that time it ran great . Then I had trouble starting it . There's no codes , no check engine light , no oil leaks or coolant leaks . The icp-dsd reads 780 psi while cranking , FICM reads 48v . All other repairs were done by Hallas Performance . Performed wiggle test on wiring and connectors. The FICM is missing the rubber insulators . It will start cold all day as long as you turn it off quickly , but if you drive it , it won't start if it's driven about a mile . When it cools off it will start .
secondragoons is offline
post #2 of 3 Old 09-05-2013, 09:12 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Do a search for air testing the HPOP.... It's a good place to start.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 3 Old 09-06-2013, 05:34 PM Thread Starter
thanks RollinEarly99 , I'll try that .
