99' 7.3 wont start driving me nuts - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-05-2013, 04:59 PM Thread Starter
So I bought a 99 7.3 non running with a "bad pcm". Did what i could to confirm the diagnosis, by having a local diesel guy run his snap on scan tool. It communicated but would intermittently just stop comm. So I replaced it,had it flashed, and still no start. The "wait to start light" comes on sometimes and not others. If you turn the ignition on and off it eventually comes on. Then when wts comes on, after it shuts off, crank and no love. HPOP is full, two fresh batteries, and its not even kicking over just cranks and cranks and cranks. Oil pressure is showing on gauge, fuel bowl fills itself, and even with a squirt of ether, nothibg at all. Please help I'm getting very frustrated. Thanks so much.
powersportcomposites is offline
post #2 of 5 Old 09-05-2013, 05:45 PM Thread Starter
Also starter is brand new, as is cps
post #3 of 5 Old 09-10-2013, 02:47 AM
Check the PCM power relay and the ignition switch. PCM may be losing power.
Joe
On edit: Make sure you disconnect the glow plugs befor using ether, could go boom!!
96 F-250 XLT 7.3l Crew Cab 4X2 5-spd
jfwatson is offline
post #4 of 5 Old 09-10-2013, 04:41 AM
Turbostang500's Avatar
Even though ether isnt good to use, it should mechanically try and run on it even if it is just a little sputter.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #5 of 5 Old 09-10-2013, 08:41 PM
Thats true, if theres no sputter you may not have compression. Did you remove the air filter when you tryed ether?
jfwatson is offline
