6.0 powerstroke won't start!!!! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-30-2013, 10:27 PM Thread Starter
Hey guys I did a head gasket/stud/oil cooler job in the past couple days. got everything put back together. Oil level is good, new coolant, fuel was in the filter housing, everything seems to be ok. I knew I was going to need to crank on this thing for a little bit so I already had a battery charger hooked up. I crank on it for about 20 seconds, let it rest a minute or two, repeat. It cranks over easier and a little smoke barely rolls out of the tailpipe but it just wont start up. Wont really try to, it'll just turn over. So after continuing this for about 40 minutes or so a TBC code displays on the dash. I've never even heard of this code before. Does it have anything to do with it not starting up? Any help will be appreciated!
Highriseford907 is offline
post #2 of 2 Old 08-31-2013, 01:43 PM Thread Starter
Ok so today I got the truck started. Just let it idle for about 20 minutes then the truck starts knocking. Sounds like its coming from the air box or air intake but I know its coming from the driver side engine. So ****. I also notice that the oil on the dipstick is pretty milky. Now I don't remember if it was that bad before the rebuild but I'm thinking probably not. I don't think it can be the oil cooler though bc I replaced the oil cooler when the truck was apart. Anyways, I took the valve cover off hoping maybe one of the rocker arms or something may have fallen off. But nothing looked suspicious to me. I didn't take the pushrods out to see if they are bent but could that be what's making that? If I take the push rods out how bent is too bent? Like any bend at all? I inspected them before I put them in and none looked even a little bent. If you put them in upside down, would that make the truck do this? Also the truck is idling very rough. There's a mechanic coming to check it out tomorrow or monday but if you guys have heard about this maybe you could chime in. I've read one story of something like this but the guy had something going on with one of his pistons and ended up blowing up his engine. But the knocking isn't sounding like it's coming from that part of the engine.
