Truck immersed in water - Ford Powerstroke Diesel Forum
post #1 of 66 Old 05-26-2008, 01:14 PM Thread Starter
COLLEGE KID
lifewitlooie's Avatar
Send a message via AIM to lifewitlooie
I was going through a creek last night and got stuck. water was pretty high but below the intake. I got yanked out and now it wont start I have power. Fuel bowl looks like its all fuel. I will pull codes later but only symptom i have to work with is,
My wait to start light does not come on at all and I have a Check engine light. What would cause my wait to start light to not come on, replacement of the glow plugs maybe? thanks
p.s. my truck is out at the lake right now
Class of Aug 17, CFD
lifewitlooie is offline
post #2 of 66 Old 05-26-2008, 01:16 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
pics??????????? J/K, have you looked at all your fuses??????
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #3 of 66 Old 05-26-2008, 01:17 PM
your pcm controls that light sounds like you fried it.if it will not start that is whats wrong
badazzstroker is offline
post #4 of 66 Old 05-26-2008, 01:20 PM Thread Starter
COLLEGE KID
nooooooooo isnt that expensive?
how else could i test if my PCM is gone or not
post #5 of 66 Old 05-26-2008, 01:27 PM
test your glowplug relay see if it is getting any juice when you turn on the key.almost every time i have seen the glowplug light not on the pcm was bad.sorry man if that is what the problem is.about $500. max you can find better deals too.
post #6 of 66 Old 05-26-2008, 01:43 PM Thread Starter
COLLEGE KID
is that a tuff fix? ill search for a write up il get pics up tomorrow or so. i still have to get my truck home thanks
post #7 of 66 Old 05-26-2008, 02:12 PM
AJF
AJF's Avatar
Sounds like you need a snorkel man if you are river crossing,
Good luck with the truck though!
AJ
2001 F-250 Lariet
Ext. Short Bed 4x4
DP Tuner, JWVB, Cowl Induction Hood, 6637 Intake,
4'' MBRP Exhaust, WW, Dfuser Fooler, Mac Inc. HPO-X, CCV mod, no EBPV, DI up pipes, Bilstein schocks, Ranchhand Bumper
AJF is offline
post #8 of 66 Old 05-26-2008, 03:13 PM
RcnRln's Avatar
Or pontoons....I have a bunch of metal 55 gallon barrels you could use!
RcnRln
03 F350
6.0 4X4
cat delete
super chips
RcnRln is offline
post #9 of 66 Old 05-26-2008, 03:21 PM
ADMIN AND TECH
SCUFFY828's Avatar
no wait to start light means no power to the pcm, doesnt mean its fried , make sure you check all the fuses
ITS STOCK
SCUFFY828 is offline
post #10 of 66 Old 05-26-2008, 03:24 PM
International Threat
Marty's Avatar
For the 99-01 SD's it's fuse # 30 to check... bottom right hand side, it's a 30 amp fuse. See if that's blown. If it is, your truck won't start. Fuel bowl heater/pcm power fuse.
PCM replacement is easy, but don't know if that's your problem. Go into the movies on this site and search "DP TUNER INSTALL" and it'll come up. Good luck.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
