02 7.3 -f350 codes - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-27-2013, 09:43 AM Thread Starter
02 7.3 -f350 codes
Hello all guru's:
Truck just dies , runs great , tach just quits and dies, only after it gets hot.
will start and run fine for a while after cooling for several hours.
Throws the following codes:
p0603 - int. cntrl mod KAM error
p1670 - ef feedback signal not detected
p0340 - camshaft pos sensor circuit error.
Had camshaft sensor replaced as a recall issue by dealer couple years ago.
Any thoughts? Had to replace vsm ( vehicle security module) couple years ago , went south on me. Possible ecu issue?
hazrdus is offline
post #2 of 4 Old 08-27-2013, 10:41 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
I'd put another CPS in it right now....
NoRalPh is offline
post #3 of 4 Old 08-27-2013, 02:26 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
KAM error is nothing.
id replace cps as well.
the signal code p1670 i had pop up when my truck wouldnt start. batteries were low which shut the idm off. prevented the truck from starting.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 4 Old 08-29-2013, 05:21 PM Thread Starter
Replaced cps, seems to have fixed the problem.
hazrdus is offline
Tags
codes , ecu
